berlinonline avatar image
berlinonline asked
Victron SmartSolar MPPT Laderegler 100/20 Bluetooth Connection Problem
The whole winter my solar system was completely shut down. Yesterday I connected the battery, the MPPT 100/20 and the solar panel as usual. Everything works fine, battery is loading, but I can't connect via bluetooth to the MPPT. The MPPT won't be listed in the app and is not visible via bluetooth devices (Android Phones). I tried the following:
On my phones(s)
1. Released the Bluetooth Pairing
2. Reinstalled the Victron App
3. Tried 3 different Phones. Location service and Bluetooth switched on on every device
4. No device visible in the Victron Connect App and in the Bluetooth search
Afterwards I tried the following:
1. Disconnected the solar Panel
2. Disconnected the battery
3. Waited some minutes and then only connected the battery. Still no bluetooth device visible within the app oder via bluetooth search
Are there any options I could try?
1. Is there a way to reset the MPPT without the app?
2. Maybe a VE Direct Cable could help to find the problem?
Bluetooth
