andy156 avatar image
andy156 asked
Node-red Deploy failing - flow.json is too large
Hi, I'm trying to deploy my file and I am getting...
Deploy failed:
413 Request Entity Too Large
nginx/1.16.1
if I delete a node then this goes away. I have quite a large file now
I have tried adding
apiMaxLength: '10mb', to /data/home/nodered/.node-red/settings-user.js which should be doubling the amount I can deploy. However it hasn't changed anything.
Does anyone know what I need to do to make it work please? My flows.json file is failing at 2 megabytes Thanks
Node-RED
andy156 answered ·
I added
 client_max_body_size 15M;
to the last end of the http block in /etc/nginx/nginx.conf and that fixed it. Obviously this won't survive a reboot.
