spudgun avatar image
spudgun asked
Minimum Hardware for Victron Lithium Batteries
I'm looking to understand what hardware is required or optional for the range of Victron Lithium batteries:
12.8V/25.6V Lithium LiFePO4 Batteries
Ve.Bus BMS (Required for use with MultiPlus/Quattro only?)
Mini BMS (Required for use with non Victron inverter/charger?)
BMV (Optional?)
Battery Protect (Optional?)
Lithium HE battery
Lynx Ion BMS 400A/1000A (Required)
Any other options for the HE battery?
Lithium Superpack
No external hardware required?
Thanks for any guidance on this. Finding it hard to find a description of what is required for each type of battery. If there is a link or relevant circuit diagram anywhere then please do post it here and I'll search for answers there.
Lithium Battery
Paul B avatar image
Paul B answered ·
Hi I would suggest that you visit your local Victron agent and I am sure they can help you answer all those questions,
The questions are vairable depending on the installation so its a bit hard to rattle all those off here
