Herve RV Nizard avatar image
ESS Settings for AC1 - grid . Similar options as genset ?
EasySolar (Multi) - MPPT 100/50 - Color Control - AC Available
I am having a hard time setting the ESS the way I would like . I read carefully the manuals, looked at videos , but still cannot find what I want. I do not have a generator. But in the Victron video on ESS (https://www.youtube.com/watch?v=tbpQzEZTElI) , from 47:23, it shows the settings for generator start. This is exactly what I would like to set for AC IN .
1- I would like my solar to be the first choice for charging the batteries
2- I would like AC IN to supply only the loads - not recharge the batteries - when reaching a certain "low" voltage , close to 70% SOC.
3- I would like AC IN to stop when reaching a higher SOC (thanks to solar charging)
4- I would like AC IN for larger loads , let's say from 1000 W AC Out
And more which I found easily on the generator part of ESS settings .
Do they exist for AC IN ? Could someone help me find where ?
Thanks
Multiplus-IIESSGeneratorEasySolar All-in-OneAC PV Coupling
Paul B avatar image
then you need to setup ASSISTANTS in the mutlplus to do this
these are the settings I use, plus some links to read over
https://www.victronenergy.com/live/assistants:start
https://www.victronenergy.com/live/assistants:overview_of_available_assistants
Share
