What is the maximum allowed deviation between cells for a SmartLithium battery before it reports Unbalanced?
this usually depends on the BMS installed and the setting in the BMS and the difference is usually the what the lowest or highest cell is to the lowest - its not a cut and dried answer as it depends on the battery brand and its specs. usually anything over 0.1 to 0.2 v or more is to much and balancing needs to occur, but this is quite variable on personal preferences as well ON how hard the battery is being pushed.
48 People are following this question.
