Jon Baxter avatar image
Jon Baxter asked
48v 5000v multiplus LED error absorption/float and overload/temperature on
I came home after a couple days away. And my 48v 5000w multiplus quattro is showing the following LED error and wont turn on. I have disconnected the battery and let it sit several times hoping it would reset but no luck. It has been working fine for almost a year now. Any ideas what the issue could be?
Attached is a picture of the LEDs.
MultiPlus Quattro Inverter Chargererror
Alexandra avatar image
Alexandra answered ·
@Jon Baxter
Have you opened the unit to see if there is alot of dust build up internally? If there is clean it out, dont spin the fans. If that is not the issue then something has failed internally.
It would have to be sent in to your supplier or distribution centre for an assessment.
