evan-1 avatar image
evan-1 asked
PV Voltage and Curent not tracked on VRM graph - RS MPPT450/100
Hi.
There is a similar question (with no answer) related to an MPPT 100/50 hence this new post.
On the dashboard I can see the voltage and current for both trackers.
Why is this data not tracked on VRM chart for PV voltage and current?
I am using a Freedom One LiPo Battery and the 2 multis shows "external Control". I am assuming this means the Multi's are under the BMS control.
Not sure what other info would be of help but happy to engage further.
VRMrs450
