eyub avatar image
eyub asked
stop battery charging from generator only
hello guys
I have a little bit complicated setting for a system with a quattro 10 kva and 2 ac input, the system is working in ESS mode. I would like to stop my batteries from being charged by the generator since it is a housing complex and the generator KWH is higher than the grid KWH cost so I don't want to charge the batteries with the generator but i need the generator for some essential load and i want to charge the batteries only using the grid is this posssible
battery chargingGenerator
Alexandra avatar image
Alexandra answered ·
@eyub
Yes, you can disable the internal charger or reduce charge amps with the charge current control
assistant, based on ac input
eyub avatar image eyub commented ·
I know that i can limit the charging current using dvcc but how can i do it based on ac input? is it from the color control or the ve configure ?
Alexandra avatar image Alexandra ♦ eyub commented ·
Ve Configure. It is an assistant on the inverter.
