Good evening everyone,
I have 2 strings of 7 panels each on the MPPT RS 450/100
Im planning to add more ,should I make it 2x9 panels or 2x10?
What margin of safety to keep regarding max Voc?
Panels are canadian solar 410w -Voc 37.2,Isc 14.01
@ukXan As per the manual re note 1, what is your battery float voltage?
Voc goes up with lower temperatures. What is the lowest temp your array will experience?
Perhaps use the mppt calculator?
Pylontech battery float as per victron documentation is 51 V
Many thanks,
I too have the RS 450/100 (well x2) and x9 panels on each tracker and live in the same area as you. Over the coldest sunny day when on float i was still well within spec of the 450/100 a and my voc is a bit higher than yours so i would say x10 on each tracker but as suggested check the calculator first.
The only other thing to consider is shading if x10 have one shaded you might be better off with x9.
Dave.
This is just what i have seen and not a recommendation or suggestion you need to make up your own mind.
So in summary would 9 panels on each tracker be safer then given Voc 37.2,Isc 14.01?
VOC of 10 panels in series is 372V at 25C. Temp coefficient for voltage is 0.26%/C.
You have a voltage margin of 450-372=78V. To make the maths clearer, let's take a ridiculous case - temp drops to -25C or 50C below the reference standard. So voltage increase will be 50*.0026*372=48.36V. This still leave a margin of almost 30V.
That's safe in my book. Unless the beast from the east comes in really really cold... ;-)
36 People are following this question.
