craig-westlake avatar image
craig-westlake asked
Can you use VDO Capacitive Sender with GX Tank140
I have a yacht with four existing tanks - all with VDO capacitive tank senders (0-20mA).
These senders have only two wires - Sense and Ground.
Here is some information on the sender and connection to the analog meter.
https://www.dynamicelements.co.za/blog/fresh-water-level-sensor-n02-240-802-wiring-and-setup-n31
I am strugling with the wiring on this one and not even sure they can be used with GX Tank 140, but if anyone can help that would be great.
As a side note, I would obviously prefer not to replace all the working senders, but if I need to what are people using?
Thanks
Craig
tank monitor
Robert avatar image
Robert answered ·
Hello, the manual from the Tank140 "said" 0-10V or 4-20mA.
I'm sure VDO use 4-20mA Sensors as well.
4mA empty
20mA full
Never heard about 0-20mA.
Should work.
Best regards Robert
