Gary Pacey avatar image
Gary Pacey asked
NMEA-2000 Instance change using Actisense NGT1
I have connected the NGT1 to the NMEA network and can see the BMV-712 using VE.Direct NMEA interface (V1.2) PGN's 127508 and 127506. I can type in the new instance number but it does not stick. I can change the Multi VE.BUS NMEA2000 instances with an issue (PGN 127507 and 127509).
Why won't the battery monitor instances stick?
BMV Battery MonitorNMEA 2000 - N2K
Gary Pacey answered ·
Had to load the latest USB drivers from Actisense. Problem solved.
Victron BMV battery monitors product page
