I have victron PWM 30 A regulate with controller and I wonder if I can use it with the new Victron lithum super pack batterty or do perhaps do I have to use a regulater between the PWM regulater and the battery for overload?
You can use a PWM but they are noware as effecint as the newer MPPT units
only the latest PWM charger with LCD can charge lithium batteries, as far as I know.
thanks, I have the LCD and what I can see...there is a 4:th alternativ to do manuel settings...for the victron super pack is it 14,4 volt & float 13,3 volt? ... or should I set i lower to be on the safe side?
9 People are following this question.
