combatdiver avatar image
combatdiver asked
How can I limit the battery lifePo SOC to 60% load state, with MPPTs 100/30
Hi !
I have installed a few days Lifepo4 Batteries in my vessel. 2 each 400 Ahm drop in batteries each one with its own BMS. Tewaycell, with bluetooth in the BMS. I can see all the parameters inside.
So I'm searching for some answers, I guess they are easy, but Im a little confused. if you please:
1º Lifepo4 are like litium batteries ( laptop, cellphone..)...in the way of , Are they must kept under 60% to extend their live? The thing is, they were delivered near 100% of charge. But I don't need that capacity for the daylife, just for emergencies (a long trip in the ocean). I bought this capacity because it was cheaper than 300Ah ones and available.
2º If 1º quesion = YES, in all my MPPTs (there are 4), can I set them to archive the 60% and stop chaging?. Maybe setting Absortion and floating voltage below, maybe 13.2 , or both the same?
3º If 1º & 2º are ok, Do you know if the victron battery chargers 220ac/12v, has the feature to stop to charge batteries up to the choosen SOC?. Mine has no even a Voltage absortion/float or anything to set and reach a certain SOC
Maybe this questions have been answerer somewhere, all and over gainbut I would wish to have a confirmation, because I read something but Im not sure
Thanks a lot
MPPT Controllersbattery chargingMPPT SmartSolarbattery
hjohnson avatar image
hjohnson answered ·
I‘m running a DIY battery with a BMS that integrates (REC ABMS). In my case, when I tie up my boat for a long period of time, I’ll set an artifiical DVCC limit to 13.2v which will let the battery drift down to 60% or not. Then once a month, or before I go out on an overnight trip, I’ll shut that off and let the battery charge all the way up to 100%.
combatdiver avatar image combatdiver commented ·
The point would be if there is necesary and even if exists, some device, that we can put between chargers and LifePo4 battterties, to manage such of these things: when to charge, when not, up to certain SOC, set time to leave the boat for long period, set time to normal use, from time to time selected have a total charge or total discharge...
matt1309 avatar image
matt1309 answered ·
Hi @CombatDiver
1. If you look at below LiFePO4 charging curve this might help understand my answer.
However the answer is no LiFePO4 cells do not have to be kept under 60% to extend their life. LiFePO4 voltages are relatively flat throughout charging/discharging cycle until close to the the very ends. ie close to 100% or close to 0%. At close to 100% the voltage then spikes (around 3.45v per cell you'll need to multiple this number by however many cells are in your battery, likely 4 if 12v system). Essentially a LiFePO4 battery wont be under any additional stress until the steep part of the charge curve (above 3.4v ish, people will debate on this number but around 3.4v if you're conservative up to 3.55v if not)
2. Given the answer is no to 1 then no need to worry on this question. However you're right if you wanted to do that you'd just set an upper limit using lower absorption/float voltage would be the way to do it. However no need given answer above.
3. I don't believe there is a way to set it based on SoC however setting a limit based on SoC wouldn't be ideal in my opinion especially for LiFePO4. Given to track SoC of LiFePO4 we have to count amps in vs amps out (unless we're at steep part of the curve ie 100% or 0%)
For lead acid the charge curve is relatively straight so voltage is a decent indicator for SoC ie if 12v = 0% SoC and 14v = 100% then in lead acid you could guess that 13v is 50% and you'd probably be close.
However for LiFePO4 isn't a straight line so it's hard to work our SoC from voltage alone without being at 100% or 0% (the steep part of the curve). Hence why smartshunts etc count amps in vs amps out.
If i use the graph below as an example at 20% SoC, the voltages looks to be around 3.25v and at 80% is around 3.3v, so it's so hard to tell SoC from voltage because it's so flat until the steep part of the curve. Therefore what most people will do is set their float/absorption voltages at the bottom of the sleep part of the curve. That way you're getting most energy out of the battery without stressing it too much with the higher voltage you would seen on the steep part of the curve.
Additionally looking at the graph for your first question. At 60% voltage is just below 3.3v so the battery isn't under any more stress that it is at 90%.
Hope this is useful. Let me know if you have any further questions. A really great resources for information and tests on LiFePO4 is a youtube channel called off-grid garage.
Nev avatar image
Nev answered ·
1. Unnecessary.
We have been fulltime travelling in our mororhome here in NZ for 9 years.
Our 4 cell 300Ah LiFePO4 Sinopoly battery has survived all those years with just a c4% capacity loss. In Ah from the original c315 to 302 last November. It both starts our 3.9l turbo diesel engine often multiple times a day and powers all our goodies.
I aim to keep the battery at 100% SOC but that never occurs in practice. Typically 100% by 2pm and 75% SOC at sunrise.
I suspect that those theoretical 50 to 80% numbers often bandied about are just that - theories.
combatdiver answered ·
Thanks to both guys!.
I shot the question, because I watch that with lithium is ok to do that, and some people stated in internet that it was the same for th LifePo4. Now Im fine
I have a second question. In my case, I will have full 100% all the days the LifePo4 set, almost always. And only at night I will be taking enegy for the batteries, but not too much. I guess most of the times, I will have discharges of 10% no more. So, I keep with this discharge profile, Do you think my batteries are going to last shorter?
Thanks BR
Nev avatar image
Nev answered ·
The battery may or may not last a few days or weeks less over its lifetime but you will NEVER know anyway. Insignificance comes to mind.
Just keep using your battery as usual. Fill it, use it and fill it again.
Surely that was the whole purpose of installing the battery anyway.
Enjoy it along with all all the advantages!
Thanks. I asked this cuestion because I noticed using the acid lead batteries, that if they are aged but fine ( 5 years), and you leave them months connected to battery charged, (always full), then the battery performance after that period, goes to unnacceptable, I mean, they can't withstand a night discharging
It happened to me also with another used battery, that I used as crank engine battery. It was ok, but after 2 year always been full almost all the days ( in my boat as soon as sun is rising , crank battery is getting power of the PV), and this battery was dead in short time
And also in my cars. If you dont charge the battery, or you are charging all the time, but not using it, they'll be dead.
That's why I asked
Thnaks
kevgermany avatar image
kevgermany answered ·
Something missing in this discussion is the BMS and cell balancing within the batteries. The BMS will only balance the cells when the battery is close to 100% charged. It's necessary to charge to 100% regularly. If this isn't done, out of balance cells can lead to premature battery failure.
