Tom Ranson avatar image
Tom Ranson asked
Safe integration of wind turbine
Hi all,
Grid parallel ESS
24V system
SmartShunt 500A
2x MPPT 100/30
Multiplus ii
Cerbo Gx
4x UltraMax LiFePo4 102Ah 24 "drop in" batteries with internal BMS in parallel (408 Ah)
500W wind turbine (not yet integrated)
I have a small wind turbine which I want to safely integrate into my existing ESS setup.
This is the charge controller which was supplied with it (Amazon link) https://amzn.eu/d/d7SEs6C
1. Can I safely use this type of wind controller to integrate with my existing setup? I would intend to place another SmartShunt in-between this and the existing Shunt and configure it as a DC energy meter, so as to see the energy listed separately on thr Cerbo.
1a. If I can't use this controller, what sort of controller can I use?
2. How do I prevent overcharging of the batteries? I don't want to create an unsafe situation.
3. Anything else I should be aware of?
Many thanks as always.
Hydro and Wind Power
nesswill avatar image nesswill commented ·
Hi have a Merlec turbine (yet to be integrated) i find all reputable turbines come with there own Controller so i would be very carful picking one, and i know its a cliché but you pay for what you get.
I too would use option 1. (note yet to be done so it might change)
Dave.
Tom Ranson avatar image Tom Ranson nesswill commented ·
@nesswill I'd be interested to know more about your plans. I'm thinking I need a more advanced controller that supports voltage cut off and dump load in order to avoid over charging the batteries?
nesswill answered ·
Tom yes you're correct a good quality controller is a must.
4 comments
Tom Ranson avatar image Tom Ranson commented ·
@nesswill do you have any recommendations please, or any other observations I need to consider?
nesswill avatar image nesswill Tom Ranson commented ·
Hi Tom until i get this setup there is not much i can add, another member suggested this "Have you considered using a dedicated shunt for the DC loads?"
I will try this once setup but i have only just got the turbine so got to build the tower/ put it up and wire everything so a bit of work to do yet.
I can only recommend what i have/are using but other members can point you to other ideas.
This thread is interesting if you have not see it yet.
I will keep you updated if you like.
Dave.
@nesswill many thanks Dave. Yes I was also planning to install a second shunt as a DC meter for the turbine circuit. I'd be interested to hear more about what wind controller you are going to use. Please keep me informed with your progress.
Hi Tom,
The controller (MPC1 ) comes with the turbine see under Battery Management i will putting it up this weekend so will let you know.
Please let me know what you go for too.
Cheers Dave.
