Last week my remote Console on VRM was disabled. The strange thing is that I have not disabled it by my self. How can this happen and is it possible to enable it without be on site?
I can't think of an obvious answer.
Have you maybe changed anything in VRM that could result in the VRM portal ID changing. This is what the venus os/cerbo gx uses to connect to VRM, so if the ID is changed on VRM (or venus/cerbo) then it would result in VRM stopping working until correct ID is reinput into VRM.
However I'm not aware of any reason it could stop without you having changed something. Unless the internet connection to the venus os/cerbo gx was disconnected?
In regards to reconnecting it remotely unless you've got remote access to the network (ie a VPN/ssh Tunnel or equivalent remote access) I'm not aware of anyway to change venus os/cerbo gx settings if vrm remote access is disabled
46 People are following this question.
