I've got a DIY Lifepo4 battery bank that I'm going to be installing in a somewhat unique fashion. I have 16 304AH 3.2v cells that I'm going to put into a 12v bank with 4 cells in parallel then series those groups for a 12v bank. However the unique part is I'm going to install the 4 cell in parallel into a battery box so if they need to be removed from a camper van it's manageable weight (ignore the series busbar connections as I have matching flexible busbars on order). The BMS is going to be a REC Active BMS so will be external to the battery boxes.
My question is the first photo. Per wiring unlimited, it says to wire parallel strings in one of these suggestions:Since the "load" is going to be the battery box terminal, would there be any benefit to running a wire from each cell or would that not matter since I already have a bus bar? Just go with option 1 (Diagonally)?
