Hi Victron experts,
Just wondering if Victron MPPTs and Inverter/Chargers are can be used with Enersys lead acid batteries:
Thank you so much in advance.
Hi Victron experts,
The datasheet doesn't give charging details, this should be checked before purchase.
But they appear to be standard high end lead acid and will be ok unless they have unusual charge requirements that can't be set on the Victron side.
34 People are following this question.
