bm97ppc avatar image
bm97ppc asked
Can I use an assistant (timer) to control AC In on a Quattro?
Can I have 2 AC feeds into a Quattro (AC IN 1 & AC IN 2) and disable AC 1 between 04:00 to 23:59 everyday.
Basically use a second supply (attached to AC IN 1) on cheap rate between 00:00 and 04:00.
I know AC IN 1 will take precedence over AC IN 2 and I could put an external contactor / timer on it to achieve this but wondered if I can do it with an assistant?
MultiPlus Quattro Inverter ChargerAssistants
wkirby avatar image
wkirby answered ·
I presume that there is no sort of GX device connected to the Quattro.
A Quattro doesn't have a real time clock in it, so it's not possible to perform time based functions in it. Time based functions would need to be performed by an external device.
bm97ppc answered ·
Yes Cerbo GX is available, so I assume this would be Node-Red then. OK so can the AC input be disabled via Node-Red?
wkirby avatar image wkirby ♦♦ commented ·
Node-Red may not be necessary. There is a way to do it using a combination of assistants and the CerboGX for doing the time base functions.
Have a look at this document:
https://www.victronenergy.com/live/drafts:acin_ignore_timer_using_ccgx_gen_start_stop_example
