d4h-ottmar avatar image
d4h-ottmar asked
Grid Feed-in max limit sometimes exceeded
Hi Guys,
running a 3-Phase Multiplus II in ESS with limited grid feed-in to 1500W and observe a lot more (up to 3000W) from time to time. This always happens when the load/critical load is particularly high. Can someone explain why this happens?
Thanks for help and ideas.
feed-in limit
Unbalanced phase loading and three phase AC PV inverters do this.
I have seen that the AC PV does not like unbalanced phases.
The other question is do you have phase compensation on though?
d4h-ottmar answered ·
Hi Alexandra,
thanks for your answer. Yes, phase compensation ist on, because it's highly recommended from Victron. I also notice unbalanced phase loads sometimes, but why should this result in such a difference as expected from the settings. For me it looks like the control algorithm is not working properly in this case.
Screenshot ( ESS limit = 1500W) attached:
Total of all phases or individual phase on the regulation? If you try the other does it help?
