jaro2k avatar image
jaro2k asked
How to prioritise Zero feed-in limits across multiple Fronius PV invertors?
I have a very specific setup of ESS configuration with 2 Fronius Inverters (while one is regular and one is hybrid with 12kWh Fronius battery connected).
ESS is setup with Zero Feed in.
All works perfectly except one small deficiency. When there is zero feed-in limit activated.. the power decrease is applied to both Fronius invertors equily which is making system a bit less eficient.
It would be more efficient if I could priorities limitation across Invertors so hybrid one gets limited first and regular one gets limited as last. This way the hybrid one will shift it's surplus PV energy to it's local battery while the regular one still goes full speed.
I guess it's more like a feature request rather than a question on how to setup.
Thank you for your thoughts.
ESSFroniusfeed-in limit
