matt1309 avatar image
matt1309 asked
Mppt dc export, grid limit, is this normal normal behaviour
Hi
When dc export enabled (with grid limit of 2.5kw) and a fully battery (absorbtion or float). The mppt acts not how I expected.
It goes to 0 output when grid limit is hit, battery then begins to discharge slightly and the the mppt goes back to full power. This causes voltage in battery to spike even in absorption/float stage.
I thought the mppt would slowly scale not go 0 to max and then keep repeating said process.
Is that the correct way the mppt should perform or am I missing a setting somewhere?
MPPT Controllersgridfeed-in limit
matt1309 answered ·
To anyone that stumbled upon this. For me the solution was enabling DVCC and I assume the specific setting SVS as I have no others enabled.
MPPT Product Page
MPPT Error codes
