chris-t avatar image
chris-t asked
100a Autotransformer: Can I power a 110v and 230v leg at the same time?
I need guidance. I will have a single-phase 4000w pure sine inverter connected to the 100a Victron autotransformer to run a 230v well pump and a 110v outlet and a 60w light bulb and need to run them at the same time. My simple diagram is what I think the wiring should be from the inverter terminal block. (and yes, I know the 100a is far more than I need and will repurpose when the 32a arrives)
1) Can that be done?
2) Is the wiring correct the way I have it?
Autotransformer
