motylu avatar image
motylu asked
Limit MultiPlus-II feed-in current in parallel installation
is it possible to limit feed-in current individually in Multis in parallel installation? I want to limit feed-in current to grid to 8 A for each Multi to achieve max. 16 A per phase.
In Grid code settings for Europe there is "Max. AC current xx.x % of INom" desribed as "Maximum AC current for charge and feed in". If I set this parameter to 72.5 % (approx. 8 A) in both Multis, will it work as I expected?
Many thanks for answer.
Multiplus-IIcurrent limitfeed-in limit
Rob Duthie avatar image
Rob Duthie answered ·
Hi
The master unit takes control of the current sharing you set that to what you like and it tell the other inverter to do the same, as far as i know it can't be set for each one.
motylu avatar image motylu commented ·
Hello @Rob Duthie ,
so if I set 8 A in master and slave Multi in one phase (let's say L3), total feed-in current to grid in phase L3 will be limited to 8 A or 16 A? Or all Multis will be limited according to master in phase L1?
Limited to the number of parallel units so 16 Amps if master is set to 8Amps
motylu avatar image
motylu answered ·
Hi @Rob Duthie ,
I tested this settings in three installations and unfortunately system does not work as expected... If I limit both Multis in one phase (two Multis in parallel) to 72.5 % (approx. 8 A), total output current is limited to 16 A, but not only output current for feed-in, but also to home installation connected on AC-out. So this settings seems to be "inverter" output limit, but not only limit for feed-in, as is described in VEConfigure dialog.
Is it possible to limit only output current/power for feed-in (to AC-in) in parallel Multis, but not limiting output current/power to AC-out?
