I have the MultiPlus-II 48/3000/35-50 120V with 4 LifePo 12V in series. What is the recommended charger setting for this setup? I can't seem to find for a 48v setup.
Thanks!
Jeff
Thanks!
Jeff
12V batteries in series are not the best choice.
Do you have some kind of BMS?
Do you have access to the terminals of the individual cells?
Before connecting those 4 batteries in series, you must fully charge them all with a 12V LiFePO4 charger (or an MPPT set to 12V battery).
73 People are following this question.
How can Multiplus 1 be used to increase charge power in ESS system with Multiplus 2 and GX
>10kVA and dedicated production meter
Camper Van Schematic - please critique
Are my MultiPlus II VE Config charger settings correct for 4 x Omnipower 200Ah batteries?
firmware compatibility three phase system MultiGrid-II and MultiPlus-II
