There are mppts connected to the cerbo that we use in different areas. I want to watch the data of MPPTs on a single pc. I need to use IP address for this. Can i do this with Cerbo and MPPT or any recommendation..
Yes, you can browse to the console of the CerboGX using its IP address:
Thank you ..I know that.but ı am not sure that Can I get the data which read over cerbo GX using the IP address through my own program? Because we have to see the status of solar panels and batteries in more than 40 places in our own system.
VRM is not useful for all of them separately, I need to see them all from a single interface. Will it be enough for me to use the ip address? Or do u know that is there any process for that.
thank in advance
I like to use ModbusTCP to do this and then use a third party software to render the data, in this case Home assistant.
It is also possible to use Grafana if you prefer that.
53 People are following this question.
