bkoon avatar image
bkoon asked
Can PWM Light Stay Connected During Generator Engine Start?
I'm curious if my PWM Light bluesolar (for 12v battery) charge controller is okay to stay connected with an autostart feature on the 32kva genset. Or should I keep the generator off until disconnecting the two solar panels before using the battery to start? Normally this setup is for a battery for camping, but the generator batteries usually are dead before I need the generator and tired of having to jumpstart from a vehicle.
I'm currently using the PWM on H (manual) setting, but if there is a recommendation of a different setting for my setup would appreciate hearing. Thank you
BlueSolar PWMgenerator auto start
