dorian-cameron avatar image
dorian-cameron asked
VRM RSSI Widget no Data
When i add the signal strength widget, or a custom widget with RSSI/SNR etc, it only displasy "No data".
System is Cerbo GX and Victron 4g-LTE-GSM. I can remote console and realtime control the system perfectly. Downloading the log from VRM also has no data for gateway signal strength.
Any ideas? I have multiple systems deployed and the same issue is present.
VRM
4 comments
@Dorian Cameron
These are often measurements for internal use. Not generally reported to the VRM.
For example when the CPU goes above 50°C the Bluetooth is switched off.
dorian-cameron avatar image dorian-cameron Alexandra ♦ commented ·
@Alexandra interesting thanks. Im not to concerned with the cpu temp, It is the network speed/quality data im most interested in.
Alexandra avatar image Alexandra ♦ dorian-cameron commented ·
@Dorian Cameron
Some other feedback. Those two parameters do work for a GlobalLink, not GX GSM.
I thought that might be the case. Thanks for your feedback.
