rubicon avatar image
rubicon asked
HDMI extension cable
Will a HDMI extension cable (not splitter) work with the Touch 50? I need to add a 15-20ft extension to the OEM cable to reach my Cerbo GX. If an extension cable can be used (not supported), should a standard HDMI cable be used or one with combined Ethernet included? Powering the USB with an extension is pretty easy.
touchscreen
Alexandra avatar image
Alexandra answered ·
@Rubicon
https://community.victronenergy.com/questions/51944/can-i-use-hdmi-splitters-or-extension-cables-or-ex.html
What I have found works well is a cheap tablet that connects to the cerbo WiFi hotspot and has the remote screen up on display.
dwmarine avatar image
dwmarine answered ·
We have used HDMI female/ female adaptors and a normal 10metre HDMI cable to extend the length a few times now.
Everything has worked well. no issues.
@dwmarine
Does this include the touch?
If it does what extenders did you use?
dwmarine answered ·
the HDMI female/ female adaptor is about 20mm long, basically, it's just a joiner that joins two standard HDMI cables together, Our local Victron dealer suggested this.
Sorry, don't have any photos. I have used powered extenders on other projects in the past, but this is cheap, easy and worked.
