jonnyhottub avatar image
jonnyhottub asked
Mppt disappears from easysolar
I had successfully added a smart solar not to and easy solar 2. System via direct connect ports and it has been working very success fully over the last 4 days but this morning it’s disappeared from the system and UX display. I have tried connecting via usb and direct but nothing I have set mppt back to factory defaults but still not showing. I believe the two systems are linked via Bluetooth. I did add a display to the mppt last night. So I am at a loss. See pictures
MPPT SmartSolarEasySolar All-in-One
Alexandra avatar image
Alexandra answered ·
@jonnyhottub
The smart network is designed for systems with no GX device.
The two together cause weird issues like the one you have. You will have to remove the smart network if you are using the GX.
jonnyhottub avatar image jonnyhottub commented ·
Thanks will try that
EasySolar 1600 product page
EasySolar-II GX 3000 & 5000 product page
