As stated, How do I stop the black left-hand menu blocking the dashboard page? I have 'shrunk' the page with Chrome zoom settings but that doesn't help.
Please can anyone advise me how to do this?
TIA
TIA
Can you post a pic or screenshot?
Thanks for your reply. I've actually got this going on another answer thread now if you would like to take a look: https://community.victronenergy.com/questions/142982/vrm-not-updating.html?childToView=181432#answer-181432
What system and browser do you use? Did you try another browser?
Ok, here you are:
System is win 10, browser is chrome.
I don't have any problems with Chrome.
Do you have any add-ons installed in Chrome? If yes disable them all, just for testing.
That you have a horizontal scroll bar could be a clue - i.e. for some reason the browser isn't following the page's css instructions.
You could visit https://css3test.com/ and see what score you get. I'm seeing 63% on Chrome Version 108.0.5359.125 (Official Build) (64-bit) on Windows 11
Chrome works fine for me.
Try and adjust your screen resolution (?) for that tab. 3 dots at the top of the page > zoom > adjust % down.
Turned off extensions but no luck.
Checked these 2 settings?
Outofideas...
Again, don't think that's relevant - try it yourself and see if you can replicate what the OP is seeing. On a browser that is obeying the css instructions, once a min pixel width is detected, the left menu reduces to a top-left 'hamburger' icon. If it doesn't reduce to an icon, it's v likely a browser-not-obeying-css issue.
Scale didn't help but resolution does! I can see the whole thing now.
Only thing is the rest of my stuff is hard to read particularly the internet tabs on chrome. Oh well can't have it both ways I suppose. Or can I? Can I set the resolution to be that way just for the VRM portal? Or is the css thing (don't know what that is) the root cause and is it fixable?
In an ideal world the black menu would be closable.
You can set a different "zoom" % for each individual browser tab. Chrome seems to remember the Zoom % the next time you open that website.
You can also tell chrome to set zoom % and font size upon opening up tabs. 3 dots at top right > settings > appearance.
You said it's a Windows 10 system.
But it's a PC/laptop or a tablet? x86 or ARM?
The resolution looks low for a PC monitor.
Did you already tried another browser?
I haven't tried another browser yet.
Might pay to check the manufacturers website.
I tried it that way but the scaling (I mean the zoom % on chrome and the scaling in windows screen settings) makes many things bigger but not the chrome tabs.
Are you sure that scaling (the one in the Windows 10 Display Settings) does not increase everything in size?
Zoom in Chrome (or other browser) only increases/decreases the webpage content. So it won't make the tabs bigger.
For LCDs, the resolution should always be set as the native resolution of the display. Any other resolution degrades the image clarity.
Which resolution did you set?
What scaling (%) have you used?
Scaling I have on 150% (it says) but when I change the scaling it shows up as if it was set to 110% so I don't know where it is actually set. I have tried various settings of scale to no avail.
Johnone: what's CSS and how do I fix the problem?
Can you do the following:
1. Set the display resolution to the native 1920x1080.
2. Set the scaling (in Windows 10 Display Settings) to 100%.
3. Open Chrome and open a few tabs in it. Make a screenshot.
4. Close Chrome.
5 Change the scaling to 150% (in Windows 10 Display Settings).
6. Open Chrome and again open a few tabs. Make another screenshot.
Can you please just try another browser to eliminate or confirm a CSS issue?
Microsoft Edge (based on Chrome) should be installed on your system by default.
Tried Edge and it works fine with VRM portal.
From a web developer perspective, it's kind of amusing to see all the experts on here going on about screen resolution, scaling and even the video drivers! To repeat, what the OP's screenshots show is the browser not following the web page css instructions - "when the screen width goes below a set size, reduce the left navigation pane to a top-left icon".
So, why isn't the OP's browser following what the page asks it to do? It's an interesting question but given nobody else is seeing the issue, questionable that it's a matter for a Victron forum.
He did wrote that when using the native resolution (I assume he tried with the native resolution), the issue goes away:
He said that disabling browser extensions does not fix it.
Can he improve/fix Chrome browser by himself? Unlikely.
Can he change resolution and scaling by himself? Very easy. And it fixes the issue.
I did try with Chrome on a Windows 10 PC and when I resize the window to a small size, VRM page is displayed correctly in my case.
It's not a fix, it's a kludge - ignoring what the actual issue is, and instead forcing the user to change screen resolution for all uses!
@Guy Stewart (Victron Community Manager) Looking through this, probably a good idea to pass it on, what Dou you think?
49 People are following this question.
