Anyone have and issue of pylontech force l2 intermittent bms? it is not state of charge or voltage related. Site is 90 minutes away and being intermittent it only fails when I'm away!
So i have been to site and made a change, matthew.mccrimmond@cclcomponents.com siad to swap the the stack around and make a different one the master - worked a treat, thanks Matt
Faults with Victron equipment are best discussed directly with your dealer - this can be formalised with this support request form.
31 People are following this question.
