Think topic says it all.
Where do I get the newest firmware for the MultiPlus.
Current is 2609430.
Current is 2609430.
Hello Sebastian,
Here is the guide to updating firmware on Multiplus:
https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
This will be improved to be a much simpler procedure shortly, but for now it is intended for those with training.
Did you read that document? It is described -
New firmware files are available from Victron Professional. To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload.”
If you read that and it is not a clear enough description to understand, let me know and I will try to re-write it in another way.
Can the Firmware version not be found by simply opening VEConfigure and clicking on 'Target' in the menu bar and then 'Show Software Version'? If so, why doesn't 'Software' read 'Firmware' (confusing)? Again, if so, is this action also available within the newer configuration software VEBusQuickConfigure? Unfortunately, I cannot get that software to work with my Mk3-USB (VE.Bus to USB) dongle despite the fact that it works with VEConfigure nominally...
Also, do I understand that having bought 2 Multiplus-IIs some 18 months apart and with one reporting 'Software' (firmare) version 2623478 and the other 2626456, that it will not be possible to configure them to work in parallel even with a firmware update? I say this as the config software states that both MP-IIs must have identical firmware versions and clearly that is not possible if the first 4 digits on one is '2623' and the other '2626'...?
Lastly, in terms of what the correct latest firmware version is for the 2 above MP-IIs, can someone please confirm that the required config files are 2623490 and 2626456 respectively (found under 'VE.Bus (Multis, Inverters and Quattros)' > '26 - 230VAC Products with large microprocessor' > '400 Assistant firmwares'...)?
MW
Isle of Colonsay
Scotland
Do you have a GX device and is your system connected to the VRM portal? You can now do upgrades via VRM which will identify the correct firmware. Also, consider using VictronConnect with your phone and an adapter for the mk3 dongle. Again it identifies the latest firmware which is actually embedded in VictronConnect so field upgrades are easier as long as you update it regularly. You have very much answered your own question with regards to parallel installation is not possible with different product version numbers. Finally, the most up to date versions of firmware is indeed in located where you found it.
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
9 People are following this question.
