Trung avatar image
Trung asked
Multiplus Assistants
Hi All
I wondered if there are anyone out there who knows about setting up MPII Assistants in VE Config.
Setup: MPII, CerboGX, Lifepo4 batteries.
Would anyone know how I set up assistants to Turn the Charger on at a certain time and then to turn if off after a few hours - e.g. Inverter ON at 8.30pm and Off at 1.30am?
Many thanks
Trung
Multiplus-IIAssistants
snoobler avatar image
snoobler answered ·
Not an assistant pro at all, but it sounds like you need ESS with scheduled charging:
https://www.victronenergy.com/media/pg/Energy_Storage_System/en/configuration.html#UUID-27898816-d249-d1e4-935c-b715b85eb6d5
ESS is capable of much more, so I suspect the hard part will be figuring out how to ignore everything you don't need. :)
Trung avatar image Trung commented ·
Hi Snoobler - many thanks for your response / comments - looks like it is exactly the thing I am looking for - will try out over the weekend.
thank you..
trung
snoobler avatar image snoobler Trung commented ·
Hope it works out. My system is off-grid, so I can't use ESS, but I'd be interested in a follow-up if you're successful.
