I switched to lithium batteries and need to change settings for voltage and charger output current, what position for dip switches is needed and how to save? I have mk3 but cannot connect. Serial # HQ 1741SYFA3
HQ1741 is not too old and should work with the MK3.
Maybe there is a problem with the driver in Windows?
big problems with older computers and drivers, I cannot get either windows xp drivers to work or Mac OS high Sierra either , so just need to understand the dip switches, there are so many instructions and versions of saving and entering, that I am thoroughly confused
Just need to cut charging rate down to 50amps
47 People are following this question.
