cargol66 avatar image
cargol66 asked
does smart battery sense works with Cerbo ?
Best Wishes to everybody for this new year.
I'm trying to connect a smart battery sensor with bluetooth to a Cerbo GX but It seems to be impossible to create a Ve.smart network with CerboGX. So how to do it ? is this sensor compatible with CerboGX ?
Thanks for your help
Bruno.
cerbo gxSmart Battery SenseVE.Smart Network
Alexandra avatar image
Alexandra answered ·
@Cargol66
Hi Bruno,
No the emart battery sense has no communication with the cerbo. It is designed for non GX systems.
cargol66 answered ·
Thanks a lot for your quick answer.
Do you think it's possible to link the smart sensor to a smart device like Smart solar MPPT 150/85 via VE.smart network and then to link MPPT to CerboGX via VE.direct bus, so Cerbo gets temperature and battery voltage informations by this way ?
projectwaterlily avatar image
projectwaterlily answered ·
If you have it connected to an MPPT that uses it, the the Cerbo will use it off the MPPT...
cargol66 avatar image cargol66 commented ·
HI,
Yes, except that smart sense is not compatible with older MPPTs.
See :https://www.victronenergy.com/media/pg/VE.Smart_Networking/en/limitations.html
Regards.
