jterrag avatar image
jterrag asked
Is cerbo's power connector standard?
Hi.
Has anyone figured out if the little plastic connector at one end of the cerbo's power cable is something standard that can be found on, say, digikey?
(and, yes, I've searched the forum and I've seen the posts with the standard "just ask your local dealer". They don't have the little connector or even the whole cable as spare parts)
Thanks
cerbo gx
jterrag answered ·
I'll answer my own question. On one side of the connector you can read WJ15EDGKD -3.81.
3.81 (mm) is the distance between the poles (I think). WJ15EDGKD would seem to be some kind of product code but if you google it you won't find a place to buy them. The two letters WJ in the code seem to indicate one particular producer of that type of connector (WANJIE).
So, if you remove the part that is producer-specific and just search for 15EDGKD or 15EDG, for example on aliexpress, you'll find various options. I bought these and they seem very good.
Hartley Gardner avatar image
Hartley Gardner answered ·
Also called "Phoenix" connectors - the 2-pin is easily found on Amazon, but I haven't found the 8-pin double-row version that is used for the tank & temp sensors.
jterrag avatar image jterrag commented ·
Maybe you mean the Mini Phoenix connectors? Those look like the ones used in the cerbo. The "normal size" Phoenix connectors seem quite different.
