Is it necessary to have LOM detection enabled when using virtual switch with ignore ac input? Just wondering if the constant humming of the easy solar 2 will stop if I disable LOM detection.
Thank you.
Thank you.
I changed the grid to none in veconfigure and it does not seem to make a difference. The transformer hum level is low but audible.
79 People are following this question.
