mb4331 avatar image
mb4331 asked
Recording the power consumption of different devices using the EM24 / Cerbo GX
Hi everybody,
in the near future I will uprade my existing installation with a battery and victron components.
The system will look like this:
Energy-Meter: Victron EM24 (replaces the exisiting Sunny-Home-Manager 2.0)
System-Controller: Victron Cerbo GX
Battery Inverter: Victron Multiplus 2 48/5000
PV-Inverter: SMA Tripower 15000
Now the question:
Is it possible with this Victron-setup to record the power consumption of single devices (e.g. heat-pump)?
At the moment I'm doing this with the Sunny-Home-Manager, which reads the S0-Signal of a standard DIN-Rail-meter using the Smart-Appliance-Enabler running on a Raspberry PI.
All the data is shown in the SMA Sunny-Portal.
I havent't read anything about reading the S0-Signal with an EM24 or the Cerbo GX.
For sure another option would be to install an additional energy-meter (ET340) just for the heat-pump.
But this would be an expensive solution.
Has anybody another idea how to realize that?
cerbo gxvictronem24
