All was running fine, the setup is: VenusOS (large) on pi3b - usb serial connection to JDB bms - 2x usb to MPPT chargers - 1x usb setup to Multiplus 12/1600/40 Setup is in ESS mode, ran perfectly fine for almost a year in this specific setup. Now all of the sudden the Multi appears as 'off' on in VRM, and state 'unknown' in remote console. When I ssh into the RPi and type `dmesg` i see the following errors:
[18778.189640] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32 [18778.197763] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32 [18779.181226] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32 [18780.182971] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32 [18781.183976] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32 [18782.186723] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32 [18784.886473] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32 [18785.884238] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32 [18786.886221] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32 [18787.881970] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32 [18788.880856] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32 [18789.883878] ftdi_sio ttyUSB0: failed to set flow control: -32 [18792.635854] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32 [18793.631222] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32 [18794.634098] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
Anyone any idea what I might be facing? rebooting the RPi will result in finding the multi again, and within a few hours the same issue occurs. I get the feeling the Multi is fine, it's either the VenusOS or the Original Victron cable that connects the Multi and the RPi. Any hints / help in debugging this is welcome!
