corkforest avatar image
corkforest asked
Victron SmartSolar 100/50 Equalisation voltage issues (will not exceed Absorb V)
Hi All
I wonder if anyone else has run into this issue?
When I put the equalisation on, it seems to be limited to the Absorption voltage.
my settings are to equalise at 32V and Absorb at 29.2V
when I equalise it will not go higher than 29.2 unless I change the Absorb voltage then it will instantly move up to new setting.
Could this firmware issue?
I am running latest firmware v1.59 for controller and v2.41 for interface
MPPT SmartSolarequalisation
snoobler avatar image
snoobler answered ·
Hello again.
What is your Eq current % setting? This is a current restriction on equalization.
The default is 8% or 8% of 50A = 4A.
