Hi, I’m testing a new setup with 2 x 180w panel in series connected to an mppt 100/20. VMP 35v, VOC 45v. Have been two overcast day so there is little to no sun at all and I’m noticing a strange behavior of the voltage. It jumps up and down from 20v to 50v, up and down all the time in a matter of seconds. Power at this stage range from 0 to a maximum of 10w as there is no sun. I have a 20w panel here and just to test I connected it to the controller and the voltage is really steady to 17v and the power around 2w. In addition to this the trends are strange, it records the variable voltage from present time back to 2/3 minuts, so the graph is a zig zag up and down, if after 10 minuts I go back and check that point of the graph again seems like the line flattened making an everage of the fluctuating voltage, attached 2 screenshot of the same moment, the first made at present and one made after several time going back to the same exact moment. Any idea? Thanks in advance
![632f5569-c74b-4b35-a35a-d667e77e2701.png](/storage/attachments/45963-74cbaba0-3cc7-4b68-8da5-901c2d71d243.png)
![585c09f3-7f99-4f0e-8928-7a1c3c244b71.png](/storage/attachments/45971-585c09f3-7f99-4f0e-8928-7a1c3c244b71.png)
