mufassa avatar image
mufassa asked
VRM Bug - AC In
Is anyone else experiencing this in VRM? The numbers are just not adding up:
PV is AC-out connected. AC Loads are actually around 500-600w right now. Inverters themselves use around 360w (120ish each). PV for some reason decreases the load shown - but this then somehow makes it look as if 1kW is being exported to the grid, even though L1 - L3 in the same box clearly show it isn't....
Metering done by Inverter (no external meter connected to Cerbo).
I can't imagine this is in any way config if the numbers in the Grid (AC1-In) box don't even add up correctly...
VRM
Is this a new installation or were there recent changes?
mufassa avatar image mufassa nickdb ♦♦ commented ·
Installation about 3 months ago, PV inverter added to the install 1.5 months ago. Unsure how that changes anything though,
239.9*4.6 = 1.1kW on L1 for example, but not in VRM...
nickdb avatar image nickdb ♦♦ mufassa commented ·
When an issue appears it helps to know if it was fine before and what might have changed.
There isn't enough about your setup here to take a guess, there aren't any VRM issues that we are aware of, so I would check all settings etc.
Is VRM at least showing realtime data? What does the remote console show?
