samwood avatar image
samwood asked
Orion TR Smart 12/12 - 18 No Output Voltage
Hello
I recently set up a Orion Tr Smart in my vehicle. It worked for about 3 weeks before (and it worked amazingly) it just stopped putting out voltage. For the time I used it, I only used it on Power Supply Mode. Now it won't work on either mode.
Both LED's on respective Hz show that it is functioning 100%. But it just shows "--" where the Output Voltage should be. I have disconnected all loads and tested at the output terminals.
I disconnected Input then reconnected to restart it and it momentarily jumps to 9V on output then dies again.
I tried the exact same tests in Charger mode and the same story.
I am a big fan of Victron products but lately I have had some disappointing experiences. In the last 4 months I have had to replace 3 x MPPT 75/15's for no apparent reason. Now hoping that it will not be the case with the Orion as well.
Any advice on the above would be highly appreciated!
orion-tr smartorion dc-dc
