Kelly Armfield avatar image
Charge Controller MPPT-150-70 Algorithm USER setting
I’m using a BlueSolar Charge Controller MPPT-150-70. A few months ago I upgraded the software version to 2.05 (from 2.00). The charge algorithm has always been set to ‘USER’, and I have always set the absorption time to 2 hours (flooded lead acid batteries). Since the software upgrade the absorption time varies and it seems the algorithm is adaptive rather than fixed because it is not observing the pre-set absorption time, even though I have selected ‘USER’ and reset the absorption time to 2 hours. Can anyone suggest a possible cause and solution please?
Thanks in advance.
charge controller error
Thanks for your comments. I'm running the v2.05 firmware and suspect this may be the issue. Where can I obtain an earlier version, say v2.00?
Share
Paul B avatar image
Hi, There has just been a release of a new firmware version 1.41 ,its got a lot of fixes arond these areas of operation.
Please upgrade and see if this helps
1 comment Share
2.05 is the latest listed version for the VE.Can models. How that fits in the scheme of things I have no idea.
