The battery voltage settings are like the default values 37.2/ 43 and 42 V but despite of well loaded battery (85%) the alarm repeats several times per day.
What settings have to be changed to avoid the battery alarm?
Are you using ess assistant. There are also triggers there.
Needs the MK3 or over the vrm programming.
30 People are following this question.
