kirby avatar image
kirby asked
How to determine Cerbo GX is connected to a battery BMS properly?
I have Victron MultiPlus connected with Cerbo GX.
I want to connect Cerbo GX with a battery BMS (no matter which way we use).
How I can see Cerbo GX communicates with BMS properly? I assume see to it in Remote Console.
cerbo gxBMS
Louis van der Walt avatar image
Louis van der Walt answered ·
In the Device List view of your Remote Console you will see the battery listed there if it is connected. When no battery is connected then you will only see the MPPTs and Inverter listed along with Notifications and Settings.
