bertrum avatar image
bertrum asked
Permanent Temperature Alarm
Anyone had any problems with the internal temperature alarm? My system has a permanent temperature alarm. I suspect it is the internal temperature chip that went faulty. Also can someone advise what the chip details is?
My system details. Victron Multiplus 12/3000/120/50
Temperature Alarm
ryanbland007 avatar image
ryanbland007 answered ·
Hi I have the same problem on my 15 KVA Quattro , don’t seem to be any firm answers on this forum , could I ask what you found ? Thx
gsking avatar image
gsking answered ·
I have the same issue. I came in and the fan is on saying It’s overtemp and it won’t run. But it says 27C. Resetting it doesn’t help.
michel-diakaba avatar image
michel-diakaba answered ·
I same the same issue with Miltuplus 48/2000/25
nickdb avatar image
nickdb answered ·
Do you have a shunt installed? If so, does it have a temp sensor? If not, check that the aux setting on it is not set to temp.
