I want to set up a 2 amp trickle charge for my rarely used generator starter battery. Can the amperage be regulated on the small controllers?
If you are referring to the Load Output on the MPPT charge controllers then no, it cannot be adjusted for Voltage or current regulation.
It's purpose if for driving loads, not for battery charging.
6 People are following this question.
