Odd avatar image
Odd asked
Lynx shunt and distributor problem
Hello everyone.
I have a problem that I can't figure out. Has a lynx shunt, lynx power in and lynx distributor.
It's been 14 days since I was at the cabin and charged the batteries. when I log into vrm I see that the battery percentage is still 65%, but the volts have gone from 13.15 to 11.63.
Multiplus is switched off. Anyone have any good suggestions on what I've done wrong here.
I have 2 * 200 amp lithiums battery.
attaching some pictures
soc = 65 %
voltage is 11,65. in lithium voltage charge chart it is less than 10 % left.
still have time to go 14 h ?
lynx shunt
Odd avatar image
Odd answered ·
Looks like the battery was almost empty. Multiplus tunrn itselv down.
No i have started charging.
soc is now --.
wonder if the is some problem with the lynx shunt.
kevgermany avatar image
kevgermany answered ·
Sounds as if you have a load bypassing the shunt. Do you have a ground/earth connection direct to the battery negative? Or any other connections there?
-- means here that it cannot calculate state of charge, probably because it hasn't synched to 100%. This will change once full charge reached.
Odd avatar image
Odd answered ·
No ground connection from battery to earth or other connection directly to battery.
Has charged battery for 2 hours. Now Lynx shunt docent show any state of charge.
- 2 w. Multiplus ii off
Turning on Multiplus - 48 w.
Think this is right. but no soc
Lynx Shunt VE Can online manual
