jkmann avatar image
jkmann asked
Smart Battery Protect (SBP) 65A OK to control a 40A heating load via a thermostat?
I'm unclear as to whether the SBP is capable of performing as a relay for a heating load. Although its a solid state relay, the manual describes it as switching occationally. I'm wondering if I can connect an Open on Rise thermostat to the H terminal and a 40A heating load through the SBP. This would result in cycling the SBP up to 200 times a day. That's no problem for a typical SSR, but I'm not clear on whether this is a suitable application for the SBP. Any guidance on this application?
battery protect
